[mapguide-users] fusion error - searchStr.test is not a function
sebafr
sebafr at gmail.com
Thu Apr 5 11:02:42 PDT 2018
That's a good discussion, Jackie!
I think 'test' is a method of the searchstr object that derives from
Array.prototype.find.
Testing, after Gordon's tips, on handling the versions in google api, I
noticed that the latest version is assumed whenever no version is reported
in the google api call. The last version in development is 3.32.8 and this
searchstr.temp function does not exist in this context and for some reason,
in the load of the google map, this routine that runs the searchStr.temp is
executed and therefore gives the commented error. When we use any other
version before that, in the map load, it simply does not pass through these
lines in fusionSF.js, that is, it does not give an error, but it does not
mean that it exists, but that simply in the previous versions of google api
this routine is not called. Now why is running this now, only the google
team could respond.
Best Regards
Sebafr
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
