[mapguide-users] MGOS 3.1.1 Data Presentation in the Properties Pane (Fusion)
Jackie Ng jumpinjackie at gmail.com
Fri Aug 3 02:59:03 PDT 2018
Do the feature property values over the wire (ie. The XML/JSON responses when
you open your browser dev tools) look the same as they did in Fusion (circa
MGOS 2.5)?
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
