[mapguide-users] MGOS 3.1.1 Data Presentation in the Properties Pane (Fusion)
Mike Herel
mike.herel at gmail.com
Fri Aug 3 06:55:32 PDT 2018
Hi Jackie,
The data comes back in 2.5 via Selection.php and has the date/time as
displayed in the Properties Pane "5.4.2010" (Just date as we want when
there is not time component).
The JSON data structure looks different coming from 3.1.1 and comes back
via mapagent.fcgi and has the date as "2010-04-05 00:00:00"
I hope this is what you were asking for.
Each of these point to their own Oracle 12 instance which are supposed to
be identical. I will point my 3.1.1 installation to the same database as
out 2.5 installation just to be sure.
Thanks for your help,
Mike
On Fri, 3 Aug 2018 at 05:59 Jackie Ng <jumpinjackie at gmail.com> wrote:
> Do the feature property values over the wire (ie. The XML/JSON responses
> when
> you open your browser dev tools) look the same as they did in Fusion (circa
> MGOS 2.5)?
> - Jackie
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20180803/1c3d0279/attachment.html>
