[mapguide-users] New test build of Fusion
Jackie Ng jumpinjackie at gmail.com
Thu Aug 16 07:20:02 PDT 2018
That is an already solved problem (a bad Array.find polyfill) from 4 months
ago:
http://osgeo-org.1560.x6.nabble.com/fusion-error-searchStr-test-is-not-a-function-td5360383.html
With the new test build, you can tack on debug=1 in the query string to not
get minified stack traces from fusionSF-compressed.js, but rather the actual
un-minified source where the error occurs.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
