[mapguide-users] New test build of Fusion
Jackie Ng
jumpinjackie at gmail.com
Mon Aug 20 07:21:06 PDT 2018
The fusion that comes with MGOS 3.0 will not support bing maps (with API
key).
You need to install the post-3.0 build of Fusion that supports bing maps:
http://download.osgeo.org/mapguide/fusion/fusion-3.0.1.zip
Relevant thread was here:
http://osgeo-org.1560.x6.nabble.com/New-builds-of-Fusion-to-support-new-Bing-Maps-td5326055.html
If your ApplicationDefinition has a VirtualEarthScript element, you can
remove it. It is no longer used.
Your Bing Maps API key should be present in the appdef as a BingMapKey
extension element. Maestro (6.0m7 onwards) will insert this for you.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
