[mapguide-users] New test build of Fusion
Jackie Ng
jumpinjackie at gmail.com
Wed Aug 29 07:37:19 PDT 2018
Just an extra clarification on this behaviour from Maestro.
Maestro 6.0m10 will use this new Google Maps URL if the GoogleScript element
doesn't exist. Otherwise it tries to append the API key to the URL specified
in your existing GoogleScript element (and retain its bad URL).
This is probably not what you want, so if you want Maestro to insert the new
URL, you'll have to remove the existing GoogleScript element from your
appdef (just edit it via the XML editor), then the next time you insert the
Google Maps API key into the Fusion editor, it will insert the new Google
Maps URL.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
