Now I was able to get schema override working for Postgresql. What I did was just merge connection xml and schema xml into one xml and use it in Maestro "Edit Configuration document". Selection works also nicely now when using joins in view. Kajar -- Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
