[mapguide-users] MapGuide Service muste be restarted once in a while
Martin Morrison
martin.morrison at edsi.com
Thu Feb 8 05:33:39 PST 2018
Is the server out of system resources at the time you need to restart? Does Mapguide memory usage continually increase? Is your SQL experiencing long query times?
Martin Morrison
Infrastructure Application Engineer/Systems Analyst
Engineering Design Systems, Inc.
540.345.1410
www.edsi.com
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of frieda
Sent: Thursday, February 8, 2018 3:23 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MapGuide Service muste be restarted once in a while
Is something wrong with my values?
SessionTimerInterval = 4000
SessionTimeout = 12000
Here is an error log, at the end I restarted the service manuelly. The error is somewhere between 08:37 and 9:33.
<2018-02-06T08:37:12> 6160 Anonymous
Error: An exception occurred in FDO component.
Error occurred in Feature Source
(Library://Neunkirchen-Seelscheid/Data/NeunkirchenSeelscheid_SQL.FeatureSource):
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Spaltennamen müssen in jeder Tabelle eindeutig sein. Der Spaltenname 'tbl_Grab_ID' wurde in der Grabnummer-Tabelle mehrmals angegeben. (Cause: , Root Cause: RDBMS:
[Microsoft][ODBC SQL Server Driver][SQL Server]Spaltennamen müssen in jeder Tabelle eindeutig sein. Der Spaltenname 'tbl_Grab_ID' wurde in der Grabnummer-Tabelle mehrmals angegeben. )
StackTrace:
- MgFeatureServiceHandler.ProcessOperation() line 83 file c:\mg-2.5-x86\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpExecuteSqlNonQuery.Execute() line 150 file c:\mg-2.5-x86\mgdev\server\src\services\feature\OpExecuteSqlNonQuery.cpp
- MgServerSqlCommand.ExecuteQuery() line 131 file
c:\mg-2.5-x86\mgdev\server\src\services\feature\ServerSqlCommand.cpp
<2018-02-06T08:37:29> 9944 Anonymous
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Fehler bei ALTER TABLE DROP COLUMN, da die 'tbl_GrafikText_ID'-Spalte in der Grabbeschriftung-Tabelle nicht vorhanden ist. (Cause: , Root Cause: RDBMS:
[Microsoft][ODBC SQL Server Driver][SQL Server]Fehler bei ALTER TABLE DROP COLUMN, da die 'tbl_GrafikText_ID'-Spalte in der Grabbeschriftung-Tabelle nicht vorhanden ist. )
StackTrace:
<2018-02-06T08:37:29> 1344 Anonymous
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Spaltennamen müssen in jeder Tabelle eindeutig sein. Der Spaltenname 'LokTbl_Beschriftungsart_ID'
wurde in der Grabbeschriftung-Tabelle mehrmals angegeben. (Cause: , Root
Cause: RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Spaltennamen müssen in jeder Tabelle eindeutig sein. Der Spaltenname 'LokTbl_Beschriftungsart_ID' wurde in der Grabbeschriftung-Tabelle mehrmals angegeben. )
StackTrace:
<2018-02-06T08:37:29> 4240 Anonymous
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Spaltennamen müssen in jeder Tabelle eindeutig sein. Der Spaltenname 'tbl_Grab_ID' wurde in der Grabbeschriftung-Tabelle mehrmals angegeben. (Cause: , Root Cause: RDBMS:
[Microsoft][ODBC SQL Server Driver][SQL Server]Spaltennamen müssen in jeder Tabelle eindeutig sein. Der Spaltenname 'tbl_Grab_ID' wurde in der Grabbeschriftung-Tabelle mehrmals angegeben. )
StackTrace:
<2018-02-06T08:41:38> 6160 Anonymous
Error: Resource was not found:
Session:ef84409c-0b0f-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//FriedaMarker.FeatureSource
StackTrace:
- MgOpUpdateFeatures.Execute() line 136 file c:\mg-2.5-x86\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
- MgServerUpdateFeatures.UpdateFeatures() line 138 file c:\mg-2.5-x86\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
- MgFdoConnectionManager.Open() line 333 file c:\mg-2.5-x86\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgCacheManager.GetFeatureSourceCacheItem() line 264 file c:\mg-2.5-x86\mgdev\server\src\common\manager\CacheManager.cpp
- MgServerResourceService.GetResourceContent() line 1222 file c:\mg-2.5-x86\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgApplicationRepositoryManager.GetResourceContent() line 385 file c:\mg-2.5-x86\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
- MgResourceDefinitionManager.GetResource
(ef84409c-0b0f-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA.dbxml)()
line 320 file
c:\mg-2.5-x86\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
- MgResourceContentManager.GetDocument() line 590 file c:\mg-2.5-x86\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceDefinitionManager.GetDocument
line 476 file
- MgResourceDefinitionManager.GetDocument() line 467 file
<2018-02-06T09:00:02> 7352 Ajax Viewer 136.243.72.24
Error: Session has expired or is invalid. Please log in again.
The session
(bc9281e0-0b13-11e8-8000-448a5bd88121_en_MTI3LjAuMC4x0AFC0AFB0AFA) has expired.
StackTrace:
- MgSiteServiceHandler.ProcessOperation() line 83 file c:\mg-2.5-x86\mgdev\server\src\services\site\SiteServiceHandler.cpp
- MgOpAuthenticate.Execute() line 116 file c:\mg-2.5-x86\mgdev\server\src\services\site\OpAuthenticate.cpp
- MgServerSiteService.Authenticate() line 709 file c:\mg-2.5-x86\mgdev\server\src\services\site\ServerSiteService.cpp
- MgSecurityManager.Authenticate() line 224 file c:\mg-2.5-x86\mgdev\server\src\common\manager\SecurityManager.cpp
- MgSessionCache.GetSessionInfo() line 179 file
c:\mg-2.5-x86\mgdev\server\src\common\manager\SessionCache.cpp
<2018-02-06T09:05:17> 5480 Ajax Viewer 136.243.72.24
The session
(7852bfa8-0b14-11e8-8000-448a5bd88121_en_MTI3LjAuMC4x0AFC0AFB0AFA) has expired.
StackTrace:
<2018-02-06T09:15:02> 3860 Anonymous
Error: Cannot create repository:
Session:d4668abc-0b15-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
- MgOpCreateSession.Execute() line 109 file c:\mg-2.5-x86\mgdev\server\src\services\site\OpCreateSession.cpp
- MgServerSiteService.CreateSession() line 762 file c:\mg-2.5-x86\mgdev\server\src\services\site\ServerSiteService.cpp
- MgServerResourceService.CreateRepository() line 491 file
<2018-02-06T09:16:58> 8712 Ajax Viewer 136.243.72.24
The session
(1a2c604e-0b16-11e8-8000-448a5bd88121_en_MTI3LjAuMC4x0AFC0AFB0AFA) has expired.
StackTrace:
<2018-02-06T09:19:09> 7352 Anonymous
Session:67dea798-0b16-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:19:09> 300 Ajax Viewer 148.251.128.235
Error: Authentication failed. Please enter a valid username and password.
StackTrace:
- MgSecurityManager.Authenticate() line 190 file
<2018-02-06T09:20:39> 1480 Anonymous
Session:9d66e858-0b16-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:20:39> 5480 Ajax Viewer 148.251.128.235
StackTrace:
<2018-02-06T09:20:45> 8712 Anonymous
Session:a1558b9a-0b16-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:20:45> 9136 Ajax Viewer 148.251.128.235
StackTrace:
<2018-02-06T09:20:47> 7352 Anonymous
Session:a26c7f48-0b16-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:20:47> 300 Ajax Viewer 148.251.128.235
StackTrace:
<2018-02-06T09:21:59> 9956 Ajax Viewer 79.235.140.19 Anonymous
Error: Failed to stylize layer: Treppe
(Library://Radolfzell/Data/sp_vermessung_verm_mob_L.FeatureSource): An exception occurred in FDO component.
SDF connect failed. File does not exist or cannot be opened in specified access mode.
- MgFdoConnectionManager.CacheFdoConnection() line 1099 file c:\mg-2.5-x86\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgFdoConnectionManager.Open() line 1091 file c:\mg-2.5-x86\mgdev\server\src\common\manager\FdoConnectionManager.cpp
(Cause: , Root Cause: )
StackTrace:
- MgMappingUtil.StylizeLayers() line 892 file
c:\mg-2.5-x86\mgdev\server\src\services\mapping\MappingUtil.cpp
<2018-02-06T09:22:03> 3600 Ajax Viewer 82.165.11.179
The session
(d09a95a8-0b16-11e8-8000-208d0a1098f9_en_MTI3LjAuMC4x0AFC0AFB0AFA) has expired.
StackTrace:
<2018-02-06T09:22:33> 1344 Ajax Viewer 79.235.140.19 Anonymous
StackTrace:
<2018-02-06T09:22:35> 6880 Anonymous
Session:662131fc-0b0a-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//FriedaMarker.FeatureSource
StackTrace:
(662131fc-0b0a-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA.dbxml)()
line 320 file
line 476 file
<2018-02-06T09:22:36> 8384 Ajax Viewer 79.235.140.19 Anonymous
StackTrace:
<2018-02-06T09:30:16> 9136 Anonymous
Session:f53f433a-0b17-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:30:16> 5744 Ajax Viewer 148.251.128.235
StackTrace:
<2018-02-06T09:30:39> 300 Anonymous
Session:035e0654-0b18-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:30:39> 3860 Ajax Viewer 148.251.128.235
StackTrace:
<2018-02-06T09:31:13> 1480 Anonymous
Session:1721ea02-0b18-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:31:13> 9956 Anonymous
Session:e9fb48ee-0b07-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//FriedaMarker.FeatureSource
StackTrace:
(e9fb48ee-0b07-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA.dbxml)()
line 320 file
line 476 file
<2018-02-06T09:31:31> 5812 Anonymous
Session:225c58d0-0b18-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:31:48> 9136 Anonymous
Session:2c946126-0b18-11e8-8000-208d0a1054f9_en_MTI3LjAuMC4x0AFC0AFB0AFA//
StackTrace:
<2018-02-06T09:31:48> 5744 Ajax Viewer 148.251.128.235
StackTrace:
<2018-02-06T09:33:26> 8984
Success: Server stopped.
<2018-02-06T09:33:31> 7648
Success: Server started.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
