[mapguide-users] Slow Openstreetmap
RenoSun
renolionheart at gmail.com
Wed Jun 20 15:02:02 PDT 2018
Hi Kajar,
I think that I was facing some similar issue before too.
I modified the following codes, but I am using AIMS 2017...not exactly MG
3.1.1.
You may also want to check out the following:
1.Hotfix for Bing Map V8
https://knowledge.autodesk.com/support/infrastructure-map-server/troubleshooting/caas/downloads/content/autodesk-infrastructure-map-server-2017-bing-maps-hotfix.html
http://osgeo-org.1560.x6.nabble.com/New-builds-of-Fusion-to-support-new-Bing-Maps-td5326055.html
2.
fusionSF.js
var addElement = function (element) {
if (!element) {
return;
var src = element.textContent;
// For IE Browser
if (!src) {
src = element.text;
if (src !=
"http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2") {
if (location.protocol == 'https:') {
if (src ==
"http://maps.stamen.com/js/tile.stamen.js?v1.3.0") {
src =
"https://stamen-maps.a.ssl.fastly.net/js/tile.stamen.js";
document.writeln('<script src="' + src +
'"><\/script>');
else{
document.writeln('<script src="' + src.replace('http',
'https') + '"><\/script>');
else
document.writeln('<script src="' + src + '"><\/script>');
3.
http://osgeo-org.1560.x6.nabble.com/MapGuide-AIMS-OSM-TransportMap-and-CycleMap-API-Key-Required-td5332053.html
switch (this.layerType) {
case 'Google':
switch (this.mapTag.layerOptions.type) { //Google layer
types are actual objects
case 'G_PHYSICAL_MAP': //defined by gmap,
not a string
case 'TERRAIN':
this.mapTag.layerOptions.type =
google.maps.MapTypeId.TERRAIN;
break;
case 'G_HYBRID_MAP':
case 'HYBRID':
google.maps.MapTypeId.HYBRID;
break;
case 'G_SATELLITE_MAP':
case 'SATELLITE':
google.maps.MapTypeId.SATELLITE;
break;
case 'G_NORMAL_MAP':
case 'ROADMAP':
google.maps.MapTypeId.ROADMAP;
default:
// For the re-loaded Google layers
if (this.mapTag.layerOptions.type ==
google.maps.MapTypeId.TERRAIN)
else if (this.mapTag.layerOptions.type ==
google.maps.MapTypeId.HYBRID)
google.maps.MapTypeId.SATELLITE)
else
break;
break;
case 'VirtualEarth':
this.mapTag.layerOptions.animationEnabled = false;
switch (this.mapTag.layerOptions.type) { //VE layer types
are enumerated values
case 'Aerial': //defined in VEMapStyle from
the VE api
case 'a':
this.mapTag.layerOptions.type = 'Aerial';
break;
case 'AerialWithLabels':
this.mapTag.layerOptions.type = 'AerialWithLabels';
break;
default:
this.mapTag.layerOptions.type = 'Road';
break;
this.oLayerOL = new OpenLayers.Layer.Bing({
key: Fusion.bingMapKey,
type: this.mapTag.layerOptions.type
break;
case 'Yahoo':
switch (this.mapTag.layerOptions.type) { //Yahoo is
similar to google
case 'YAHOO_MAP_SAT': //defined by YMap,
not a string
case 'YAHOO_SAT':
this.mapTag.layerOptions.type = YAHOO_MAP_SAT;
break;
case 'YAHOO_MAP_HYB':
case 'YAHOO_HYB':
this.mapTag.layerOptions.type = YAHOO_MAP_HYB;
break;
case 'YAHOO_MAP_REG':
case "YAHOO_REG":
default:
this.mapTag.layerOptions.type = YAHOO_MAP_REG;
break;
break;
case 'OpenStreetMap':
case 'OSM':
if (this.mapTag.layerOptions.type) {
this.mapTag.layerOptions.type;
else {
this.mapTag.layerOptions.type = 'Mapnik';
break;
case 'Stamen':
this.oLayerOL = new
OpenLayers.Layer[this.layerType](this.mapTag.layerOptions.type);
break;
case 'XYZ':
this.oLayerOL = new OpenLayers.Layer[this.layerType](
this.getMapName(),
this.sMapResourceId,
this.mapTag.layerOptions);
break;
default:
this.getMapName(),
this.mapTag.layerParams,
break;
if (!this.oLayerOL) {
if (this.layerType == 'OpenStreetMap' || this.layerType ==
'OSM') {
//Test OSM sub-type before falling back to
OpenLayers.Layer.OSM
//if (typeof
(OpenLayers.Layer.OSM[this.mapTag.layerOptions.type]) != 'undefined') {
//this.oLayerOL = new
OpenLayers.Layer.OSM[this.mapTag.layerOptions.type](this.getMapName(), null,
//console.log('test1: ' +
this.mapTag.extension.Options[0].type[0]);
//} else {
//console.log("mapTagExtensionOptionType " +
if (this.mapTag.extension.Options[0].type[0] == "Mapnik") {
this.oLayerOL = new
else if (this.mapTag.extension.Options[0].type[0] ==
"CycleMap") {
OpenLayers.Layer.OSM(this.getMapName(), null, this.mapTag.layerOptions);
this.oLayerOL = new OpenLayers.Layer.OSM("t at h",
["https://a.tile.thunderforest.com/cycle/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY",
"https://b.tile.thunderforest.com/cycle/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY",
"https://c.tile.thunderforest.com/cycle/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY"]);
"TransportMap") {
["https://a.tile.thunderforest.com/transport/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY",
"https://b.tile.thunderforest.com/transport/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY",
"https://c.tile.thunderforest.com/transport/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY"]);
"Outdoors") {
["https://a.tile.thunderforest.com/outdoors/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY",
"https://b.tile.thunderforest.com/outdoors/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY",
"https://c.tile.thunderforest.com/outdoors/${z}/${x}/${y}.png?apikey=YOUR_THUNDERFOREST_KEY"]);
else {
this.oLayerOL = new
OpenLayers.Layer[this.layerType](this.getMapName(),
//fractionalZoom not permitted with tiled base layers
regardless
this.mapWidget.fractionalZoom = false;
this.mapWidget.oMapOL.setOptions({ fractionalZoom: false });
this.oLayerOL.events.register("loadstart", this, this.loadStart);
this.oLayerOL.events.register("loadend", this, this.loadEnd);
this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
I hope any of these may help you.
Reno
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
