[mapguide-users] How to Use Maestro API Local Native Connection?
rexuli rexliyuchau at gmail.com
Fri Aug 2 00:39:09 PDT 2019
Mapguide version: 3.1.2
Maestro API Version: 6.0m10
Platform: Windows Server 2008
MapGuide will become unresponsive during peak hours. When I check the
documents, I found that there is a connection call LocalNative. But I cannot
make it work, could someone give a help?
Other than that, I have some other questions:
- Is LocalNative is "Connect via TCP/IP" in Mastro GUI login or "Connect
Locally"?
- Can LocalNative help for performance?
- Does use Postgresql10.6/Postgis 2.5 will help for MapGuide Performance?
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
