[mapguide-users] Mapguide 4K issue
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Wed Dec 11 07:18:41 PST 2019
Try making the browser half screen size and see if that works? Then keep increasing in size until you get a null image/error return. There are default image sizes that are typically set in most WMS services, and 4K has been typically more than historical default values..  These may be set to some limit that you are surpassing.
bobb
> On Dec 11, 2019, at 9:09 AM, Kajar <kajar.kuldsepp at gmail.com> wrote:
> Think Before You Click: This email originated outside our organization.
> Hi!
> I'm experiencing strange issue using Mapguide map application in 4K monitor.
> Problem: when I open map in 4K monitor then WMS layers are not become
> visible.
> For FHD monitor or viewing it in laptop screen those WMS layers are visible.
> At first I thought its some browser issue, but currently same same issue
> happens with Chrome and also Firefox. Of course I use latest browser
> versions, maybe this is the source of issue.
> Actually previously(with my old laptop) I was able to see those WMS layers
> in 4K resolution without issue.
> Cant figure out is it still some browser issue or what else it can be.
> Maybe enyone else have experiencing same problem and found some fix for
> that.
> Kajar
> Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
