[mapguide-users] React Layout Resource Loading Error
techdude1996 techrules08041 at yahoo.com
Fri Jan 11 08:56:35 PST 2019
I'm attempting to try out the react layout. I built it from source because
the older release also gave me this issue. I hoped that building the latest
from github would fix it, but didn't.
I am getting a 559 MgResourceNotFoundException when trying to load
mapagent.fcgi?MAPDEFINITION...MAP-B.MapDefinition...
It successfully loads:
mapagent.fcgi
mapagent.fcgi?SESSION...WEB.ApplicationDefinition...
mapagent.fcgi?MAPAGENT...MAP-A.MapDefinition...
mapagent.fcgi?MAPAGENT...MAP-C.MapDefinition...
but not
mapagent.fcgi?MAPAGENT...MAP-B.MapDefinition...
Mapguide shows this error up top:
"An error occurred during startup"
"Attempted to load the following resource, but it was not found:
Library://Place/4_WEB/WEB.ApplicationDefinition"
I checked with the regular flex layout, and mapagent.fcgi only calls Map A
and Map C, not Map B.
Any ideas on how to fix this?
Thanks
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
