[mapguide-users] Duplicate Labels using TileSetdefinition.
Jackie Ng
jumpinjackie at gmail.com
Wed Mar 27 08:13:31 PDT 2019
This is a general problem with line/polygon labeling for tiles.
How one generally solves the problem here is to play around with the tile
extent offset which tells the tile renderer to render a "buffered out" tile
image, which gives the label placement algorithms more breathing space for
label placement, before cropping the image back to the originally requested
size.
If that doesn't work out, then I'm afraid you will have to resort to point
feature labeling where you have maximum control over labeling.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
