[mapguide-users] google strike again v 3.1.2
יובל קימל
yuvalkimel at gmail.com
Fri May 24 07:19:19 PDT 2019
Gordon hi.
I tried you fix for the google problem/ it worked on google background but
now i have another problem I cannot select objects on the map. the error
massage in the developer tool is
<html>
<head>
<title>MgClassNotFoundException</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
</head>
<body>
The specified class was not found.
- MgRenderingServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\2.6.1\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute() line 125 file
c:\working\build_area\mapguide\2.6.1\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures() line 853 file
c:\working\build_area\mapguide\2.6.1\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection() line 1573 file
- MgServerDescribeSchema.GetClassDefinition() line 1066 file
c:\working\build_area\mapguide\2.6.1\x64\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
</body>
</html>
i am using mg 2.6.
Any help will be apprichiated
Thanks
yuval
