[mapguide-users] Load Map Package from External Server Causes Selection Error (MG 3.1.1)
kparker kparker at aesi-consulting.com
Fri May 24 08:54:41 PDT 2019
I've created a map package from a client's server and loaded it onto my own
server, both running the same version of mapguide (3.1.1.9378). After
loading the package (and repointing data sources to the local server name),
the map loads normally. We use SQL Server for database storage.
When you pick on an object on the map, mapguide selection returns every
object on that layer within the selection pane, and nothing is selected in
the map window. Normally this is a database issue, however it works as
normal once restoring my own original copy of the map package. My database
tables have proper keys and spatial indices. Anyone have any ideas? Thanks
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
