[mapguide-users] MapGuide 3.0 ODBC connection SQL Server
sm.gistec
sm.gistec at gmail.com
Mon May 27 06:11:58 PDT 2019
Hello all
I've this configuration
- Win 2008 R2 enterprise
- Mapguide 3.0 x64 in apache 2.4
- FDO 3.9
- SQL Server in another server in lan (192.168.0.4)
I've tried to connect my mapguide to SQL server using ODBC fdo driver whit
this connection string
Driver={SQL
Server};Server=192.168.0.4\SQLEXPRESS;Database=NAME;Uid=USER;Pwd=PASSWORD
but, when i test connection maestro respond me this
FDO Connection Status:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Error occurred in Feature Source
(Session:efc0bc02-807a-11e9-8000-005056012ff4_en_MTI3LjAuMC4x0B100B0F0B0E//9b3a079e-5f9c-4098-a800-44ccae4f5128.FeatureSource):
RDBMS: [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not
exist or access denied.
[Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Connect()).
- MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgFdoConnectionManager.CacheFdoConnection() line 1097 file
- MgFdoConnectionManager.Open() line 1089 file
(Cause: , Root Cause: )
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgServerFeatureService.TestConnection() line 244 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgFdoConnectionManager.Open() line 366 file
I've opened my firewalls inbound and outbound, i've insert the macaddress of
the mapguide server in the white list connection SQL Server
What I'm missing?
Someone help?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
