[mapguide-users] MapGuide 3.0 ODBC connection SQL Server
Scott Hameister
scotth at mpowerinnovations.com
Mon May 27 06:38:00 PDT 2019
Do you have SQL set up to accept IP traffic I think it's called Named
Pipes?
On Mon, May 27, 2019, 8:12 AM sm.gistec <sm.gistec at gmail.com> wrote:
> Hello all
> I've this configuration
> - Win 2008 R2 enterprise
> - Mapguide 3.0 x64 in apache 2.4
> - FDO 3.9
> - SQL Server in another server in lan (192.168.0.4)
> I've tried to connect my mapguide to SQL server using ODBC fdo driver whit
> this connection string
> Driver={SQL
> Server};Server=192.168.0.4\SQLEXPRESS;Database=NAME;Uid=USER;Pwd=PASSWORD
> but, when i test connection maestro respond me this
> FDO Connection Status:
> The remote server returned an error: (559) MgFdoException.:
> An exception occurred in FDO component.
> Error occurred in Feature Source
> (Session:efc0bc02-807a-11e9-8000-005056012ff4_en_MTI3LjAuMC4x0B100B0F0B0E//9b3a079e-5f9c-4098-a800-44ccae4f5128.FeatureSource):
> RDBMS: [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not
> exist or access denied.
> [Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Connect()).
> - MgFdoConnectionManager.Open() line 333 file
> c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> - MgFdoConnectionManager.CacheFdoConnection() line 1097 file
> - MgFdoConnectionManager.Open() line 1089 file
> (Cause: , Root Cause: )
> - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpTestFeatureSourceConnection.Execute() line 100 file
> c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
> - MgServerFeatureService.TestConnection() line 244 file
> c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
> - MgFdoConnectionManager.Open() line 366 file
> I've opened my firewalls inbound and outbound, i've insert the macaddress
> of
> the mapguide server in the white list connection SQL Server
> What I'm missing?
> Someone help?
> Thank you
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20190527/f2f3000f/attachment.html>
