[mapguide-users] Coordinate transformation from CSRS to LL84
pcardinal pierre.cardinal at sympatico.ca
Fri Nov 22 13:49:31 PST 2019
Your data should use the coordinate system
PROJCS["CSRS.UTM-13N",GEOGCS["LL-CSRS",DATUM["CSRS",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",-105.00000000000000],PARAMETER["scale_factor",0.9996],PARAMETER["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]
and your map should use the coordinate system
GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329251994]]
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
