[mapguide-users] 500 Runtime Error aspxerrorpath mapguide/mapviewernet/setselection.aspx
    RenoSun
    renolionheart at gmail.com
    Tue Sep 24 12:03:51 PDT 2019
Thanks a lot Jackie!
I realized that I actually do not have to use setselection.[aspx|php|jsp] at
all. I am still using "GETSELECTIONXML.php" for now
(https://mapguide.wordpress.com/2013/06/11/autodesk-infrastructure-map-server-auto-zoom-on-load/)
However, I assume this "GETSELECTIONXML.php" solution will probably not work
with MapGuide 4.0? If so, I will modify my code to use "QUERYMAPFEATURES"
with proper JS function codes.
Will this improve performance of SetSelection at all?
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
