[mapguide-users] Fusion Error in version 3.1.2 and 4.0 preview 1
Liglio
liglio at pobox.com
Tue Sep 24 15:30:08 PDT 2019
I installed the two versions and got the same error "Uncaught
ReferenceError: mapAgentUrl is not defined". I modified the index.html to
load FusionSF.js to see the exact location of the error, and in both
versions is the same location.
var getSiteVersion = function(sessionId, callback) {
var xhr = getXmlHttpRequest();
// THE NEXT LINE mapAgentUrl IS NOT DEFINED !!!
xhr.open("GET", mapAgentUrl +
"?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&SESSION="+
sessionId, true);
xhr.onload = function (e) {
if (xhr.readyState === 4) {
if (xhr.status === 200) {
var verXML = xhr.responseXML.documentElement;
var el = verXML.getElementsByTagName("Version")[0];
var version = el.textContent || el.text;
var bits = version.split('.');
callback([
parseInt(bits[0]),
parseInt(bits[1]),
parseInt(bits[2]),
parseInt(bits[3])
} else {
console.error(xhr.statusText);
xhr.onerror = function (e) {
xhr.send(null);
The function before this one in FusionSF.js, mapAgentUrl is passed as
parameter:
var fetchAppDef = function(mapAgentUrl, appDefUrl, sessionId,
onAppDefFetched) {
but in getSiteVersion the variable mapAgentUrl is not defined.
I think is a recurrent problem at the code.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
