[mapguide-users] FW: Migration/Upgrade to Mapguide
Matze
schramm at kom21.de
Thu Feb 6 00:49:12 PST 2020
I would do the migration as followed:
- Setup the new Windows Server. Keep the old one.
- For PHP, install the roles/features for IIS with CGI (for FastCGI
support)
- Check where you can find the original data (Shapes, SDF...). If they are
not inside the repository, copy/migrate them to the new server. For database
connections you maybe need to setup the ODBC connection. Have a look inside
the server.ini under [UnmanagedDataMappings]. Maybe you see some alias
paths. If you like to keep the same path strutcure, recreate it inside the
new server.
- Install the new MapGuide Open Source and new MapGuide Meastro Version
- setup the [UnmanagedDataMappings] in the new server.ini, if needed.
- then try the steps in this instruction: 2.1MigrationInstructions
<https://trac.osgeo.org/mapguide/wiki/2.1MigrationInstructions>
- If everything was without any errors, use maestro to check every
datasource. Sometime you have to resave them, when you changed the paths for
datamappings
- try to run the map in the preview.
- check the mapguide error logs
maybe I forgot something... ;)
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
