[mapguide-users] Shape Layer Issue
liglio.pessoal at nexxa.com.br liglio.pessoal at nexxa.com.br
Wed Jun 24 07:06:59 PDT 2020
Hi Jackie,
I receive several read only shapes files in a timely way (5 minutes), and my app has a timer (10 seconds) that continually is showing those files at 5 minutes range, but very often there is no file to show. So, it causes a FDO error. I also notice an continually increase of mapguide server memory usage, maybe because of this error.
I must keep this layer visible to appear in my custom layer control  of visibility (or maybe there is another way to do it?).
Regards,
  Liglio
De: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Em nome de Jackie Ng
Enviada em: quarta-feira, 24 de junho de 2020 06:45
Para: mapguide-users at lists.osgeo.org
Assunto: Re: [mapguide-users] Shape Layer Issue
Hi Liglio,
Are you continually updating the shape files underneath or doing any other concurrent read/write access to these files?
If so, then you should reconsider the use of SHP files for this kind of scenario and loading the data into a relational database, which is designed for such multi-user concurrent access.
- Jackie
I have a shape layer that I programatically point to shape files using the
feature source, continually in a timer. But sometimes there is not a file to show, and the layer must have the
attribute visible = true.
When this occurs I got an error in the log file ("The specified class was
not found."). There is something I can do to avoid this error ?
Regards,
Liglio
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20200624/8b9b8f10/attachment.html>
