[mapguide-users] Web components on same server
Charl Jameson Beukes cbeukes at nous.co.za
Tue May 5 02:03:17 PDT 2020
HI Philip,
Not having full in depth knowledge of this I think the Web component is the least of the worries.
The web component can be mapped to various drive locations over numerous ports.
The real problem comes in with the server component where environmental variables are stored and pointed.
I guess you would have to go and change quite a lot of files under the hood to have multiple Environmental variables for your different versions of MGOS installed.
Again, I might be wrong here.
Regards
Charl
-----Original Message-----
From: mapguide-users <mapguide-users-bounces at lists.osgeo.org> On Behalf Of Philip Nell
Sent: Tuesday, 05 May 2020 04:40
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Web components on same server
I know the current advice is to not have two installations of MapGuide on the same server.
My question is if this advice is related to the Web components or the Map components?
I have a case where it will be best suited to have the web components of 2 installations live on the same server for a while.
We use version 3.1.1 and only the Ajax viewer.
Thanks
Philip
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
