[mapguide-users] Web components on same server
Jackie Ng
jumpinjackie at gmail.com
Wed May 6 02:20:27 PDT 2020
By 2 installations, we mean 2 installations (of different versions) through
the windows installer.
If you are using the InstantSetup bundle (and you should for cases like
this), the "installs" should be sufficiently isolated provided you give each
"install" its own unique set of paths, port numbers, virtual paths, etc.
The only environment variable that may have contention issues is
MENTOR_DICTIONARY_PATH, but MG installs since 2.2 should refer to a path in
serverconfig.ini/webconfig.ini first before falling back on this environment
variable.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
