[mapguide-users] Maestro error creating a theme
Gordon Luckett gordon.luckett at arrowgeomatics.com
Wed Feb 24 09:25:12 PST 2021
What is the data type?  SDF, SHP?
On Wed, Feb 24, 2021 at 5:22 PM _Jon_ <jrizzo at langan.com> wrote:
> I am trying to create a theme using my data.  I have a nullable integer
> property defined that I would like to use to make a heat map for each
> feature.  In Maestro, when I click on "Create Theme" for the area style, I
> select my property, Maestro throws the following error:
> "Unable to read data from the selected column: The remote server returned
> an
> error: (559) MgFdoException.: The custom error module does not recognize
> the
> error."
> Any idea what could be going on here, or how I might work around this
> problem?  The values could range from 0 to 90 so creating the rules
> manually
> is not really practical.  Any suggestions would be greatly appreciated.
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210224/b2ec60c1/attachment.html>
