[mapguide-users] Maestro error creating a theme
_Jon_ jrizzo at Langan.com
Wed Feb 24 09:22:24 PST 2021
I am trying to create a theme using my data.  I have a nullable integer
property defined that I would like to use to make a heat map for each
feature.  In Maestro, when I click on "Create Theme" for the area style, I
select my property, Maestro throws the following error:
"Unable to read data from the selected column: The remote server returned an
error: (559) MgFdoException.: The custom error module does not recognize the
error."
Any idea what could be going on here, or how I might work around this
problem?  The values could range from 0 to 90 so creating the rules manually
is not really practical.  Any suggestions would be greatly appreciated.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
