[mapguide-users] onload select a feature
    makoychan
    makoychan at yahoo.com
    Wed Feb  3 09:31:16 PST 2021
Thanks Gordon. But a quick question about this, does this assume that you
know the map you are loading?
Because on my approach i have multiple maps and initially before anything
else i use the mapguide api to change the filter of the layer for a certain
map to load then thats the only time i needed to do a feature selection..
Right now what i am doing is on the initPanelHandler() i call do the
querycontroller.php to select a feature but this approach is somewhat a hit
or miss on the loaded maps.. because sometimes it selects the feafure 1st
then maps finishes rendering or sometimes map finishes rendering but the
selection would trigger 2-3 seconds late.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
