[mapguide-users] Tooltip - Expression Editor - IF THEN
Diego Ordonez
diordonezr at hotmail.com
Thu Jun 3 08:59:29 PDT 2021
Hello All
I have a question that in theory should be fairly easy, but I'm having trouble
Trying to show a tooltip based on the value of an attribute (From Postgresql 12 - Mapguide 4.0 Ubuntu 16.04)
The name of the column is estado, it has two values "Encendida" (ON) or "Apagada" (OFF)
'Estado: ' , estado, '</BR>',
IF ("estado" = 'Encendida', 'ON', 'OFF'),
The first line works with no issue, showing the right "estado" (status).
What is the syntax to write in the ToolTip Expression Editor ? The second line
I've tried different ways but it always shows OFF even if the LAMP is on in the database.
Thanks in advance for your help
Diego
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210603/d117f64e/attachment.html>
