[mapguide-users] Tooltip - Expression Editor - IF THEN
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Thu Jun 3 09:02:39 PDT 2021
Perhaps it's not matching?
Try the TRIM() function?
On Thu, Jun 3, 2021, 4:59 PM Diego Ordonez <diordonezr at hotmail.com> wrote:
> Hello All
> I have a question that in theory should be fairly easy, but I'm having
> trouble
> Trying to show a tooltip based on the value of an attribute (From
> Postgresql 12 - Mapguide 4.0 Ubuntu 16.04)
> The name of the column is estado, it has two values "Encendida" (ON) or
> "Apagada" (OFF)
> *'Estado: ' , estado, '</BR>', *
> *IF ("estado" = 'Encendida', 'ON', 'OFF'),*
> The first line works with no issue, showing the right "estado" (status).
> What is the syntax to write in the ToolTip Expression Editor ? The second
> line
> I've tried different ways but it always shows OFF even if the LAMP is on
> in the database.
> Thanks in advance for your help
> Diego
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210603/1efd036b/attachment.html>
