[mapguide-users] Does mapguide support rasters stored in Postgis
Jackie Ng jumpinjackie at gmail.com
Wed Jun 23 06:26:00 PDT 2021
Hi Diego,
Your best bet is to use the PostGISRaster driver in GDAL (
https://gdal.org/drivers/raster/postgisraster.html).
This implies that you'll have to replace the GDAL dll that comes with the
MapGuide installation with one from gisinternals.com which is of the same
GDAL version and is built with the same MSVC compile that we use to build
MapGuide and FDO.
Most raster format support questions can be boiled down to: Is there a GDAL
driver for it? Then just use the GDAL FDO provider (swapping out
MapGuide's GDAL dll with a fuller-featured copy elsewhere if necessary)
- Jackie
You wrote:
Does mapguide support rasters stored in Postgis ?
Any plans to implement it ?
Thank you
Diego
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210623/75a3ac5d/attachment.html>
