[mapguide-users] Does mapguide support rasters stored in Postgis
Diego Ordonez diordonezr at hotmail.com
Wed Jun 23 07:43:08 PDT 2021
Thanks for your prompt reply Jackie
What versions of MG will work with your suggested approach ? does it work also in LINUX Ubuntu 16.06 MG4 ?
From: mapguide-users <mapguide-users-bounces at lists.osgeo.org> On Behalf Of Jackie Ng
Sent: Wednesday, June 23, 2021 9:26 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Does mapguide support rasters stored in Postgis
Hi Diego,
Your best bet is to use the PostGISRaster driver in GDAL (https://gdal.org/drivers/raster/postgisraster.html).
This implies that you'll have to replace the GDAL dll that comes with the MapGuide installation with one from gisinternals.com<http://gisinternals.com> which is of the same GDAL version and is built with the same MSVC compile that we use to build MapGuide and FDO.
Most raster format support questions can be boiled down to: Is there a GDAL driver for it? Then just use the GDAL FDO provider (swapping out MapGuide's GDAL dll with a fuller-featured copy elsewhere if necessary)
- Jackie
You wrote:
Does mapguide support rasters stored in Postgis ?
Any plans to implement it ?
Thank you
Diego
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210623/4a5364ab/attachment.html>
