[mapguide-users] Does mapguide support rasters stored in Postgis
Gordon Luckett gordon.luckett at arrowgeomatics.com
Wed Jun 23 08:01:30 PDT 2021
You just need to match the GDAL compatible with the current version of MGOS
you are using.  For example, with MGOS 4 - preview 3 it uses GDAL 2.4.4
On Wed, Jun 23, 2021 at 3:43 PM Diego Ordonez <diordonezr at hotmail.com>
wrote:
> Thanks for your prompt reply Jackie
> What versions of MG will work with your suggested approach ? does it work
> also in LINUX Ubuntu 16.06 MG4 ?
> *From:* mapguide-users <mapguide-users-bounces at lists.osgeo.org> *On
> Behalf Of *Jackie Ng
> *Sent:* Wednesday, June 23, 2021 9:26 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* Re: [mapguide-users] Does mapguide support rasters stored in
> Postgis
> Hi Diego,
> Your best bet is to use the PostGISRaster driver in GDAL (
> https://gdal.org/drivers/raster/postgisraster.html).
> This implies that you'll have to replace the GDAL dll that comes with the
> MapGuide installation with one from gisinternals.com which is of the same
> GDAL version and is built with the same MSVC compile that we use to build
> MapGuide and FDO.
> Most raster format support questions can be boiled down to: Is there a
> GDAL driver for it? Then just use the GDAL FDO provider (swapping out
> MapGuide's GDAL dll with a fuller-featured copy elsewhere if necessary)
> - Jackie
> You wrote:
> Does mapguide support rasters stored in Postgis ?
> Any plans to implement it ?
> Thank you
> Diego
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210623/bed8a0fd/attachment.html>
