[mapguide-users] Does mapguide support rasters stored in Postgis
Jackie Ng
jumpinjackie at gmail.com
Wed Jun 23 23:18:24 PDT 2021
For Windows:
MGOS 4.0 Preview 3 - GDAL 2.4.4 / MSVC 2015
MGOS 3.1.2 - GDAL 2.2.3 / MSVC 2015
Older MGOS versions you can refer to GDAL provider notes on the MapGuide
trac wiki (https://trac.osgeo.org/mapguide/wiki)
For Ubuntu 16.04, we build FDO against the distro-provided GDAL version
(1.11), which should be as fully-featured as possible in terms of driver
support barring drivers/formats that require non-OSS libraries.
I did an apt-get install gdal-bin on an Ubuntu 16.04 docker container and
ran:
gdalinfo --formats
And I see PostGISRaster is on the driver list so on Linux you should be
good to go.
- Jackie
You wrote:
Thanks for your prompt reply Jackie
What versions of MG will work with your suggested approach ? does it work also
in LINUX Ubuntu 16.06 MG4 ?
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210624/875add64/attachment.html>
