[mapguide-users] Does mapguide support rasters stored in Postgis
Diego Ordonez diordonezr at hotmail.com
Fri Jun 25 10:31:37 PDT 2021
If I use MapGuide 4 Preview 3 Win10 x64, does it support the Postgis-Raster already ?
Or do I still have to patch it with the new  GDAL ?
Could you share some instructions how to patch the MG 3.1.2 with the new GDAL ?
I’m not sure what exactly means replacing the DLL
If I am going to access a Postgis Raster file, what source should I use, GDAL or Postgis?
[cid:image001.png at 01D769C6.69CC3270]
Thanks a lot for your help
Diego
From: mapguide-users <mapguide-users-bounces at lists.osgeo.org> On Behalf Of Jackie Ng
Sent: Thursday, June 24, 2021 2:18 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Does mapguide support rasters stored in Postgis
For Windows:
  MGOS 4.0 Preview 3 - GDAL 2.4.4 / MSVC 2015
  MGOS 3.1.2 - GDAL 2.2.3 / MSVC 2015
  Older MGOS versions you can refer to GDAL provider notes on the MapGuide trac wiki (https://trac.osgeo.org/mapguide/wiki)
For Ubuntu 16.04, we build FDO against the distro-provided GDAL version (1.11), which should be as fully-featured as possible in terms of driver support barring drivers/formats that require non-OSS libraries.
I did an apt-get install gdal-bin on an Ubuntu 16.04 docker container and ran:
    gdalinfo --formats
And I see PostGISRaster is on the driver list so on Linux you should be good to go.
- Jackie
You wrote:
Thanks for your prompt reply Jackie
What versions of MG will work with your suggested approach ? does it work also
in LINUX Ubuntu 16.06 MG4 ?
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210625/ca755f89/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210625/ca755f89/attachment.png>
