[mapguide-users] Fwd: MapGuide 4 and Linux
Jackie Ng jumpinjackie at gmail.com
Fri Mar 19 04:50:08 PDT 2021
As it currently stands, we are only targeting Ubuntu 16.04 64-bit.
The main reason for this is that currently MapGuide will not fully build on
Ubuntu 18.04 (and likely newer versions) due to our bundled version of PHP
(5.6) requiring OpenSSL <= 1.1.0, which is not not possible on this distro
Ubuntu 18.04 provides OpenSSL 1.1.0
Ubuntu 18.04 also provides OpenSSL 1.0, but this cannot be installed
side-by-side with the default 1.1.0 package. The 1.1.0 package is also a
dependency of several build packages.
Of course, PHP 5.6 is already getting the axe and being replaced by PHP 7
anyways with the ongoing vanilla SWIG binding work so we may (and most
likely will) bump up the version of Ubuntu to target once the work is
completed.
I will be putting out a new MapGuide 4.0 preview release in the next few
weeks (to rollover some post-preview-2 fixes for MapGuide and a significant
set of changes/fixes for FDO). This preview will still target Ubuntu 16.04.
If you have to use another distro, the current prescription is to build and
run MapGuide on an Ubuntu16-based docker image,
- Jackie
You wrote:
What versions of Linux will MapGuide 4 support?
i.e. Ubuntu 20.10?
thanks!
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210319/2e8dc2f6/attachment.html>
