[mapguide-users] Fwd: MapGuide 4 and Linux
Gordon Luckett gordon.luckett at arrowgeomatics.com
Fri Mar 19 04:52:43 PDT 2021
That's great Jackie.
Ubuntu 16 is a good choice and used by quite a few organizations.
I'll try out the docker and try the install when available.
On Fri, Mar 19, 2021, 11:50 AM Jackie Ng <jumpinjackie at gmail.com> wrote:
> As it currently stands, we are only targeting Ubuntu 16.04 64-bit.
> The main reason for this is that currently MapGuide will not fully build
> on Ubuntu 18.04 (and likely newer versions) due to our bundled version of
> PHP (5.6) requiring OpenSSL <= 1.1.0, which is not not possible on this
> distro
> Ubuntu 18.04 provides OpenSSL 1.1.0
> Ubuntu 18.04 also provides OpenSSL 1.0, but this cannot be installed
> side-by-side with the default 1.1.0 package. The 1.1.0 package is also a
> dependency of several build packages.
> Of course, PHP 5.6 is already getting the axe and being replaced by PHP 7
> anyways with the ongoing vanilla SWIG binding work so we may (and most
> likely will) bump up the version of Ubuntu to target once the work is
> completed.
> I will be putting out a new MapGuide 4.0 preview release in the next few
> weeks (to rollover some post-preview-2 fixes for MapGuide and a significant
> set of changes/fixes for FDO). This preview will still target Ubuntu 16.04.
> If you have to use another distro, the current prescription is to build
> and run MapGuide on an Ubuntu16-based docker image,
> - Jackie
> You wrote:
> What versions of Linux will MapGuide 4 support?
> i.e. Ubuntu 20.10?
> thanks!
> *Please Note: I no longer create new posts or post replies to any OSGeo
> mailing list through nabble. As a result, you most likely won't see this
> message appear on nabble's view of any OSGeo mailing list and may only see
> this message through mailing list archives or depending on your mailing
> list subscription settings, through daily message digests or automated
> notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210319/9fa5ef6e/attachment.html>
