[mapguide-users] MapGuide-Rest GeoJSON Adaptor in RC 5
Jackie Ng
jumpinjackie at gmail.com
Mon May 24 02:00:30 PDT 2021
This is due to the PHP MgGeoJsonWriter class in mapguide-rest now colliding
with the C++ class of the same name introduced in the MapGuide 4.0 API (I
am assuming you are using MGOS 4.0). There is already a fix for this, but
it is not in the rc5 package, which pre-dates a lot of the 4.0 development
work.
Until I revisit mapguide-rest after the 4.0 vanilla SWIG binding work,
you'll have to "install from source" to get this fix. Clone the latest
master commit of mapguide-rest and install all required dependencies with
PHP composer.
Hope this helps.
- Jackie
You wrote:
I am getting the following error for the GeoJSON Adaptor in mapguide-rest
PHP Fatal error: Cannot redeclare class MgGeoJsonWriter in C:\Program
Files\OSGeo\MapGuide\Web\www\rest\app\util\geojsonwriter.php on line
21
The registration.php is using require_once, so I don't know why the error
is coming up...
http://themapguyde.blogspot.com
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210524/4f96e52d/attachment.html>
