[mapguide-users] MapGuide-Rest GeoJSON Adaptor in RC 5
Gordon Luckett gordon.luckett at arrowgeomatics.com
Mon May 24 03:32:58 PDT 2021
Thanks Jackie,
I installed mapguide-rest from source and it works great with MapGuide 4.0
R2
On Mon, May 24, 2021 at 10:00 AM Jackie Ng <jumpinjackie at gmail.com> wrote:
> This is due to the PHP MgGeoJsonWriter class in mapguide-rest now
> colliding with the C++ class of the same name introduced in the MapGuide
> 4.0 API (I am assuming you are using MGOS 4.0). There is already a fix for
> this, but it is not in the rc5 package, which pre-dates a lot of the 4.0
> development work.
> Until I revisit mapguide-rest after the 4.0 vanilla SWIG binding work,
> you'll have to "install from source" to get this fix. Clone the latest
> master commit of mapguide-rest and install all required dependencies with
> PHP composer.
> Hope this helps.
> - Jackie
> You wrote:
> I am getting the following error for the GeoJSON Adaptor in mapguide-rest
> PHP Fatal error:  Cannot redeclare class MgGeoJsonWriter in C:\Program
> Files\OSGeo\MapGuide\Web\www\rest\app\util\geojsonwriter.php on line
> 21
> The registration.php is using require_once, so I don't know why the error
> is coming up...
> http://themapguyde.blogspot.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20210524/6895c97c/attachment.html>
