[mapguide-users] Mapguide React
Jackie Ng jumpinjackie at gmail.com
Thu Nov 4 03:57:46 PDT 2021
Hello Maria,
An application definition (for the most part) works with both Fusion and
mapguide-react-layout viewers. It's just that MapGuide Maestro by default
will only preview with the Fusion viewer because it does not know about
your mapguide-react-layout viewer.
I've updated the getting started page for the MapGuide Maestro setup
you need to do to unlock the ability to preview with the
Hope that helps.
- Jackie
You wrote:
I seem to be lost, i have maestro  ver 6.0.270 and i download the mapguide
react viewer zip and placed it on my C:\Program
Files\OSGeo\MapGuide\Web\www\viewer
i also have the shebouygan sample up and running.
But when i followed the steps to run the react layout, i cant seem to
create a react application definition, whenever i add new resource, the
only avaliable appdefinition i can create is fusion. and it always uses the
template on the fusion folder. Was i doing something wrong?
I am trying to follow steps here
<https://jumpinjackie.github.io/mapguide-react-layout/#/GETTING_STARTED?id=_2-create-an-application-definition>
Description
hope someone can help me out.
Thanks
 Regards,
Maria
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20211104/a6329bab/attachment.html>
