[mapguide-users] Mapguide React
anniechan03 at yahoo.com anniechan03 at yahoo.com
Mon Nov 8 20:00:20 PST 2021
Thank you Jackie and thanks for updating the guide.
Maria
Sent from Yahoo Mail on Android
  On Thu, Nov 4, 2021 at 6:58 AM, Jackie Ng<jumpinjackie at gmail.com> wrote:   Hello Maria,
An application definition (for the most part) works with both Fusion and mapguide-react-layout viewers. It's just that MapGuide Maestro by default will only preview with the Fusion viewer because it does not know about your mapguide-react-layout viewer.
I've updated the getting started page for the MapGuide Maestro setup you need to do to unlock the ability to preview with the mapguide-react-layout viewer.
Hope that helps.
- Jackie
You wrote:
I seem to be lost, i have maestro  ver 6.0.270 and i download the mapguide react viewer zip and placed it on my C:\Program Files\OSGeo\MapGuide\Web\www\viewer
i also have the shebouygan sample up and running.
But when i followed the steps to run the react layout, i cant seem to create a react application definition, whenever i add new resource, the only avaliable appdefinition i can create is fusion. and it always uses the template on the fusion folder. Was i doing something wrong?
I am trying to follow steps here
Description
hope someone can help me out.
Thanks
 Regards, Maria
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists._______________________________________________
mapguide-users mailing list
mapguide-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20211109/66f63935/attachment.html>
