[mapguide-users] CPU 100%
Gordon Luckett gordon.luckett at arrowgeomatics.com
Tue Oct 12 09:52:23 PDT 2021
Are you using WIndows or Linux?
If windows, in IIS I sometimes disable 'Rapid Fail Protection' for the
MapGuide Application Pool....
On Tue, Oct 12, 2021 at 4:51 PM Jérôme DUCKERS <jerome.duckers at gmail.com>
wrote:
> Hi Gordon,
> Thanks for your response.
> I'm just using "SDF" files and WMS.
> Jérôme.
> Le mar. 12 oct. 2021 à 16:30, Gordon Luckett <
> gordon.luckett at arrowgeomatics.com> a écrit :
>> Do you happen to have SHPFILES?  Check the IDX files and make sure they
>> do not have 0 bytes.
>> If so, what is happening is that MapGuide is creating an index, but the
>> legend refers to a value in the theme that may not exist.  For example, if
>> you colour-code your parcels by a column called Zoning and you have A11
>> zone, but that doesn't exist in the data, you may get a 0 byte idx file.
>> Just a shot in the dark.
>> On Tue, Oct 12, 2021 at 1:50 PM Jérôme DUCKERS <jerome.duckers at gmail.com>
>> wrote:
>>> Hi Guys,
>>> Since 1 month ago, we have had a problem with our mapguide process
>>> (AIMS2017).
>>> The CPU is always growing to 100%.
>>> Has anyone already encountered the issue ?
>>> I don't know how to investigate this.
>>> Thanks,
>>> Jérôme.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20211012/1b74104f/attachment.html>
