[mapguide-users] CPU 100%
Jérôme DUCKERS
jerome.duckers at gmail.com
Tue Oct 12 10:00:15 PDT 2021
Indeed windows server with iis.
I will try but in the task manager it is the mapguide service who reached
the 100%, not the w3wp.
I try your config and I keep you informed.
thanks,
Jérôme
Le mardi 12 octobre 2021, Gordon Luckett <gordon.luckett at arrowgeomatics.com>
a écrit :
> Are you using WIndows or Linux?
> If windows, in IIS I sometimes disable 'Rapid Fail Protection' for the
> MapGuide Application Pool....
> On Tue, Oct 12, 2021 at 4:51 PM Jérôme DUCKERS <jerome.duckers at gmail.com>
> wrote:
>> Hi Gordon,
>> Thanks for your response.
>> I'm just using "SDF" files and WMS.
>> Jérôme.
>> Le mar. 12 oct. 2021 à 16:30, Gordon Luckett <gordon.luckett@
>> arrowgeomatics.com> a écrit :
>>> Do you happen to have SHPFILES? Check the IDX files and make sure they
>>> do not have 0 bytes.
>>> If so, what is happening is that MapGuide is creating an index, but the
>>> legend refers to a value in the theme that may not exist. For example, if
>>> you colour-code your parcels by a column called Zoning and you have A11
>>> zone, but that doesn't exist in the data, you may get a 0 byte idx file.
>>> Just a shot in the dark.
>>> On Tue, Oct 12, 2021 at 1:50 PM Jérôme DUCKERS <jerome.duckers at gmail.com>
>>> wrote:
>>>> Hi Guys,
>>>> Since 1 month ago, we have had a problem with our mapguide process
>>>> (AIMS2017).
>>>> The CPU is always growing to 100%.
>>>> Has anyone already encountered the issue ?
>>>> I don't know how to investigate this.
>>>> Thanks,
>>>> Jérôme.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20211012/dc3f3dae/attachment.html>
