[mapguide-users] MGOS 4.0 and REST
Jackie Ng
jumpinjackie at gmail.com
Wed Aug 3 10:32:05 PDT 2022
mapguide-rest has not been maintained for years now due to competing
priorities in real life and on other projects.
I am assuming by MGOS 4.0 you are using the current preview 3 release. If
you are using my vanilla SWIG sandbox branch then I can say mapguide-rest
will definitely not work right now as that is still targeting PHP 5.6 and
the vanilla SWIG branch now bundles PHP 8.
Assuming you are on the preview 3 release that still bundles PHP 5.6, then
if you are using the 1.0 RC5 release I can say that release will not work
because it has a class that collides with a class of the same name in the
MapGuide API (MgGeoJsonWriter). All I can say is try building mapguide-rest
from git master (which renames this conflicting class) and see if that
works with your preview 3 installation.
Otherwise I would just hold off on trying to use mapguide-rest with MGOS
4.0. The next preview release of MGOS 4.0 when it drops, will ship with PHP
8.1, which means mapguide-rest will *definitely* not work for reasons
already stated above. There will need to be dev work (which I currently do
not have time for) to migrate mapguide-rest over to PHP 8.1. So all things
considered mapguide-rest will not be usable with MGOS 4.0 in the
foreseeable future until at least the final release of MGOS 4.0 is out the
door. Only then can I reasonably invest some time into migrating over
mapguide-rest.
As an aside, I am also interested in how you set up your VSCode for PHP
debugging. I only got this to work for debugging PHP scripts that are run
from the command-line. I never got this to work for PHP code running on a
web server.
- Jackie
You wrote:
Hi Jackie,
What can it be ?
MGOS 4.0 from last release with IIS under Server2012 R2
MGOS 4.0 from build with IIS under Win10
When I tried to use mapguide-REST with
http://localhost/mapguide/rest/index.php, I have the following message :
404 Page Not Found
The page you are looking for could not be found. Check the address bar to
ensure your URL is spelled correctly. If all else fails, you can visit our
home page at the link below.
Visit the Home Page <http://localhost/mapguide/rest/index.php/>
And in the VS Code debugger I have the exception Slim\Exception\Stop (line
1020 in Slim.php)
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220804/271bb325/attachment.htm>
