[mapguide-users] MGOS 4.0 and REST
pierre.cardinal at sympatico.ca
Tue Aug 2 11:34:24 PDT 2022
Mapguide-rest from last code release (mapguide-rest-master.zip) installed
with Composer
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de
Envoyé : 2 août 2022 14:29
À : mapguide-users at lists.osgeo.org
Objet : [mapguide-users] MGOS 4.0 and REST
Hi Jackie,
What can it be ?
MGOS 4.0 from last release with IIS under Server2012 R2
MGOS 4.0 from build with IIS under Win10
When I tried to use mapguide-REST with
http://localhost/mapguide/rest/index.php, I have the following message :
404 Page Not Found
The page you are looking for could not be found. Check the address bar to
ensure your URL is spelled correctly. If all else fails, you can visit our
home page at the link below.
Visit the Home Page <http://localhost/mapguide/rest/index.php/>
And in the VS Code debugger I have the exception Slim\Exception\Stop (line
1020 in Slim.php)
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220802/b359bf78/attachment.htm>
