[mapguide-users] REACT Sample
Pierre Cardinal
pierre.cardinal at sympatico.ca
Wed Aug 24 13:08:15 PDT 2022
Hi Jackie,
With MGOS (build 9862) and IIS under Win10.
I have no problem to display the REACT viewer when I am using the viewer directory (ziewer.zip or yarn install from the source) .
But when I am trying to display the REACT viewer with the sample directory, http://localhost/mapguide/sample/sample_template.html?ApplicationDefinition=Library://Samples/Sheboygan/FlexibleLayouts/React.ApplicationDefinition&locale=en
Note : I have a React flexible layout (react.xml) in FlexibleLayouts of the Sheboygan package
I have the following message :
An error occurred during startup
No resource parameter found. This viewer assumes this parameter to be set in the query string and must refer to a valid Web Layout or Application Definition. If not specified, it will try to init from a Application Definition document at appdef.json
With MGOS 4.0 P3 and IIS under Server 2012 R2
Also I have no problem with the viewer directory but, when I am trying to display the REACT viewer with the sample directory, mostly everything is OK except the « View as KML » function. When I click on « View as KML », the function returns a pop up window to download the file mapagent.fcgi.
With MGOS 4.0 P4 and IIS under Win10.
Regards,
Pierre
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220824/362a1cb3/attachment.htm>
