[mapguide-users] MGOS 4.0 Dev Trunk - Maestro - Widget Info
Jackie Ng jumpinjackie at gmail.com
Wed Jul 13 07:14:17 PDT 2022
Hi Pierre,
The Widget info button is disabled if Maestro cannot resolve the matching
widget info xml file from the fusion installation. Since it is disabled and
you say you are using a freshly built MG, it's probably because Fusion is
not installed into the expected web tier path for your freshly built MG
installation, so the widget info XML files will be 404 when Maestro tries
to request for them.
Hope that helps.
- Jackie
You wrote:
Hi Jackie,
With Maestro, what can be the cause for the "Widget
Info" button not being activated in the Widget Management window?
I don't have this problem when I use version 4.0.0 which is available for
installation but I have this problem when producing the MGOS
application from source code.
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220714/df3388f4/attachment.htm>
