[mapguide-users] MGOS 4.0 Dev Trunk - Maestro - Widget Info
pierre.cardinal at sympatico.ca
Wed Jul 13 10:11:23 PDT 2022
Hi Jackie,
Thank you for your help but finally I found the answer in the webconfig.ini file of the www directory for mapguide. There are three
Web Application Settings in the file.
Regards.
Pierre C.
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de Jackie Ng
Envoyé : 13 juillet 2022 10:14
À : mapguide-users at lists.osgeo.org
Objet : Re: [mapguide-users] MGOS 4.0 Dev Trunk - Maestro - Widget Info
Hi Pierre,
The Widget info button is disabled if Maestro cannot resolve the matching widget info xml file from the fusion installation. Since it is disabled and you say you are using a freshly built MG, it's probably because Fusion is not installed into the expected web tier path for your freshly built MG installation, so the widget info XML files will be 404 when Maestro tries to request for them.
Hope that helps.
- Jackie
You wrote:
Hi Jackie,
With Maestro, what can be the cause for the "Widget Info" button not being activated in the Widget Management window? I don't have this problem when I use version 4.0.0 which is available for installation but I have this problem when producing the MGOS application from source code.
Please Note: I no longer create new posts or post replies to any OSGeo mailing list through nabble. As a result, you most likely won't see this message appear on nabble's view of any OSGeo mailing list and may only see this message through mailing list archives or depending on your mailing list subscription settings, through daily message digests or automated notifications from the mailing lists.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220713/88b257d7/attachment.htm>
