[mapguide-users] download kml and upload kml in fusion
Hadis Alinia hadissaalinia at gmail.com
Wed May 18 21:51:52 PDT 2022
Thank you Gordon!
I came a cross with Mapguide-react-layout that has the Add/manage layer
component. I know I should add the widget as an invoke URL. In the widgets
I can see see "add WMSlayer" and I tested to add WMS but doesn't work. I am
using mapguide V.3.1.2.9484. I don't see that componnet in my widget list.
Should I do anything to add this widget? Is it the same as openlayers 2.13
that you referenced?
Under option> Editor I see mapguide layout react URL. Is this the one I
need to make a change to? What is that URL?
Thank you
HA
On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible Web
> Layout/Web Application) uses OpenLayers 2.13 and this does support KML
> parsing etc.
> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <hadissaalinia at gmail.com>
> wrote:
>> Hi,
>> I need to enable the user of my webmap application built by Mapguide to
>> overlay their kml layers in ajax view or convert CSVs with lat and lon to a
>> point data and then can download their points data as kml. Or select a
>> feature of the uploaded layer and download it as a kml. Is that even
>> possible in mapguide? I can't find an example searching on google.
>> Please advise
>> Thank you
>> HA
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/b1e345ce/attachment.htm>
