[mapguide-users] download kml and upload kml in fusion
Gordon Luckett gordon.luckett at arrowgeomatics.com
Thu May 19 04:18:38 PDT 2022
Can you send the WMS url you are trying?
On Thu., May 19, 2022, 12:52 a.m. Hadis Alinia, <hadissaalinia at gmail.com>
wrote:
> Thank you Gordon!
> I came a cross with Mapguide-react-layout that has the Add/manage layer
> component. I know I should add the widget as an invoke URL. In the widgets
> I can see see "add WMSlayer" and I tested to add WMS but doesn't work. I am
> using mapguide V.3.1.2.9484. I don't see that componnet in my widget list.
> Should I do anything to add this widget? Is it the same as openlayers 2.13
> that you referenced?
> Under option> Editor I see mapguide layout react URL. Is this the one I
> need to make a change to? What is that URL?
> Thank you
> HA
> On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
> gordon.luckett at arrowgeomatics.com> wrote:
>> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible Web
>> Layout/Web Application) uses OpenLayers 2.13 and this does support KML
>> parsing etc.
>> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <hadissaalinia at gmail.com>
>> wrote:
>>> Hi,
>>> I need to enable the user of my webmap application built by Mapguide to
>>> overlay their kml layers in ajax view or convert CSVs with lat and lon to a
>>> point data and then can download their points data as kml. Or select a
>>> feature of the uploaded layer and download it as a kml. Is that even
>>> possible in mapguide? I can't find an example searching on google.
>>> Please advise
>>> Thank you
>>> HA
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/b0b03ee6/attachment.htm>
