[mapguide-users] download kml and upload kml in fusion
Hadis Alinia
hadissaalinia at gmail.com
Thu May 19 07:54:24 PDT 2022
component://AddWMSLayer and I can see it in web\www\fusion\widgets folder.
On Thu, May 19, 2022 at 7:18 AM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> Can you send the WMS url you are trying?
> On Thu., May 19, 2022, 12:52 a.m. Hadis Alinia, <hadissaalinia at gmail.com>
> wrote:
>> Thank you Gordon!
>> I came a cross with Mapguide-react-layout that has the Add/manage layer
>> component. I know I should add the widget as an invoke URL. In the widgets
>> I can see see "add WMSlayer" and I tested to add WMS but doesn't work. I am
>> using mapguide V.3.1.2.9484. I don't see that componnet in my widget list.
>> Should I do anything to add this widget? Is it the same as openlayers 2.13
>> that you referenced?
>> Under option> Editor I see mapguide layout react URL. Is this the one I
>> need to make a change to? What is that URL?
>> Thank you
>> HA
>> On Wed, May 18, 2022 at 11:48 AM Gordon Luckett <
>>> Ajax (Basic Web Layout) does not support KML - the Fusion (Flexible Web
>>> Layout/Web Application) uses OpenLayers 2.13 and this does support KML
>>> parsing etc.
>>> On Tue, May 17, 2022 at 7:07 PM Hadis Alinia <hadissaalinia at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I need to enable the user of my webmap application built by Mapguide to
>>>> overlay their kml layers in ajax view or convert CSVs with lat and lon to a
>>>> point data and then can download their points data as kml. Or select a
>>>> feature of the uploaded layer and download it as a kml. Is that even
>>>> possible in mapguide? I can't find an example searching on google.
>>>> Please advise
>>>> Thank you
>>>> HA
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20220519/cc37c4a4/attachment.htm>
